2021-01-03 11:18 PM
Hello, I am using STM32F746 with FMC SDRAM, QSPI flash, DMA2D. I observed my display is flicking. You can check video using below link.
https://drive.google.com/file/d/1j3uyyHWHlFO-fGW23RI33Iyos6meYaB-/view?usp=sharing
Any suggestions for solving this issue.
I am using custom board with MCU 746 with below software with version :
2021-01-08 7:09 PM
@EEuge I am using using double buffer so don't need it now.
void TouchGFXGeneratedHAL::initialize()
HAL::initialize();
registerEventListener(*(Application::getInstance()));
setFrameBufferStartAddresses((void*)0xC0000000, (void*)0xC0120000, (void*)0);
}Please check my other post.
2021-01-08 9:35 PM
I"m using double buffer too!
But if I set This parameter to "false", I see the same picture, as you.
Just try to follow my advise.
2021-01-08 9:48 PM
@EEuge Ok i ll update code as below. If you get time, plz check my other post : https://community.st.com/s/question/0D53W00000TpEyoSAF/stm32-resetting-after-adding-touchgfx-task-in-freertos
HAL::initialize();
lockDMAToFrontPorch(true);
