Change scrollwheel content by a button in TouchGFX.
Karim
Is it possible to change the content of a scrollwheel by a button in the same screen.
For example I have 3 options Menu 1, Menu 2 and Menu 3 in scrollwheel when the screen appears for the firs time. I want to change these options to Menu 4 ~ Menu 6 by clicking a button in same screen.
Is there any other solution?
Thank you everyone.
Ok then before invalidate add
scrollWheel1.itemChanged(1);
scrollWheel1.itemChanged(2);
scrollWheel1.itemChanged(3);
8 REPLIES 8
MM..1
Chief II
you can do , what you need write into
scrollWheelUpdateItem(MenuElement& item, int16_t itemIndex)
thank you for your reply.
Yes I your are right and I already use it. I defined scrollWheelUpdateItem in screenview.cpp and it updates the content when change the screen from other screen to this screen.
But I want change the content by clicking a Button in current screen. (By defining an interaction for example)
Into button action place
markervariable=4;
scrollwhell.invalidate
and in
if (markervariable == 4)
else {
actual code or any other change what show
Thank you for your reply but unfortunately I still didn't get. Let me explain more.
this is in my ScreenSelectChannelView.cpp:
void ScreenSelectChannelView::scrollWheel1UpdateItem(TableContent& item, int16_t itemIndex)
    item.updateColumn1(itemIndex);
    item.updateColumn2(itemIndex);
    item.updateColumn4(presenter->getChannelName(Temp_Input_Index, itemIndex));
    touchgfx_printf("scrollWheel1UpdateItem\r\n");
void ScreenSelectChannelView::scrollWheel1UpdateCenterItem(TableSelectedRow& item, int16_t itemIndex)
    touchgfx_printf("scrollWheel1UpdateCenterItem\r\n");
These 2 functions work correctly. They update my table when I change my screen from ScreenHome to ScreenSelectChannel. I have a button in ScreenSelectChannel. I want change the content of my table by pressing the button.
As I understand you say add this section:
else {
to ScreenSelectChannelView::scrollWheel1UpdateItem and markervariable  = 4 in button action.
My problem is I don't know how to call scrollWheel1UpdateItem in button function? Or there is an other way that I don't know.
Sorry if my question is too easy.
Thank you.
In button you call
scrollWheel1.invalidate();
Thank you again for your fast replies. I searched a lot and so I don't have any way except asking here.
I already did what you say. This is my button action:
void ScreenSelectChannelView::setInputIndex1()
	Temp_Input_Index = 1;
  touchgfx_printf("setInputIndex1 %d \r\n", Temp_Input_Index);
I expect calling function "scrollWheel1UpdateItem " by pressing the button but touchgfx_printf shows it doesn't run:0693W00000KbdWjQAJ.pngIn Red section we see scrollWheel1UpdateItem and scrollWheel1UpdateCenterItem are called when I change the screen to ScreenSelectChannel. But pressing buttons doesn't call those functions.
Thank you.
Oh, Yes it works.
Thank you so much.
Thank you.:hibiscus:
