Can the touchgfx transplanted by stm32g070 use freertos? I configured freertos with stm32cubemx but it doesn't work
Yli.41
Romain DIELEMAN
It can be set but the issue is actually memory consumption. If I recall correctly there might not be enough memory space to enable FreeRTOS with the STM32G0 nucleo, or barely. If you create a custom board with the STM32G0 mcu then you add external memory I guess.
/Romain
