Can I name the screen ADJUST and Box With Border adjust?
‎2020-01-07 9:08 AM
I have a problem with Tutorial 2. I don't want to add the counter after pressing. Does not work after implementation " Using a wildcard text " ?
TouchGFX
‎2020-01-08 4:16 AM
To answer your first question: Yes, you can. Because the screen name will become classes ADJUSTView, ADJUSTPresenter, so there will be no name clashes.
Your second question, please elaborate, it's a bit unclear to me,
/Martin
‎2020-01-08 8:31 AM
Thank you with your reply. I had a confused function name.
‎2020-01-08 10:34 AM
How to display a variable on the screen. I created text <value>. How do I associate this with my variable "counter" and update it on a regular basis. The variable is global.
‎2020-01-09 2:26 AM
https://touchgfx.zendesk.com/hc/en-us/articles/205587571-Step-3-Adding-Text
Try following this tutorial
‎2020-01-09 8:32 AM
Hi Martin
Studied. A bit different from my need. My variable "counter" is set in the file "main.cpp" and not from buttons. Will it be seen in other files?
‎2020-01-09 9:34 AM
Another community member made a youtube video on how to do this. There are TouchGFX documents as well, but the video was enough to get me going
https://www.youtube.com/watch?v=majcfxr3u2E
in main.cpp in whatever task, variable gets put into a queue
in the model.cpp in the gui the data is received from the queue and passed to the presenter, which passes it to the view. (I think I got that right)
i believe you could access the data right from the view, but I think that will cause you problems later on.
Basically there is a structure to TouchGFX and its best to follow it. By using a queue you keep the GUI thread/task and your main task from accessing the variable at the same time, which is a good idea with the RTOS.
There is a similar process for sending gui data back to the main logic.
Be sure to put your code changes in the main.cpp between the user code start and end comments.
Bob
‎2020-01-09 9:44 AM
Thanks Bob. I will study it.
‎2020-01-10 12:18 AM
Combine the tutorial that i sent you with this: Integrating with hardware - https://community.st.com/s/question/0D50X0000AU4zodSQB/interfacing-with-hardware-in-touchgfx-applications
‎2020-01-10 12:19 AM
The link contains projects that you can try for certain boards which are aging a bit now, but the video that @Bob Bailey​ posted actually uses CubeMX to do it, which is really nice!
