Can DCMI, SDIO & LTDC interfaces used in same time in STM32H7B3I-EVAL without any problem?
‎2022-10-25 2:35 AM
We have an application that required to use DCMI, LTDC & SDIO in same time. we plan to use STM32H7B3I-EVAL for proof of concept. can we use it or there is limitation in using all this interfaces in same time?
DCMI
LCD-LTDC
SDIO-SDMMC
STM32H7 Series
‎2022-10-26 6:22 AM
Hi @Community member​,
Theoretically there is no limitation to use the DCMI, LTDC and SDIO at the same time in the STM32H7B3I-EVAL.
I advise you when configurate the STM32HB32I-EVAL, make sure that the DCMI, LTDC, and SDIO interfaces don't shared the same pins.
Thank you for your contribution.
Kaouthar
‎2022-10-26 6:22 AM
Kaouthar
