2020-04-18 01:29 PM
I understand the simulator doesn't know about GPIO and so on. That being said, if one wanted to manipulate the hardware from the UI actions (say, set an LED), what's the best way to do that?
Two ideas I have:
1) Use the preprocessor to comment out any code that won't run during simulation
2) Pass data two and from the main tasks via variables that are monitored on another thread.
What is suggested? As is, including the HAL libraries doesn't work without manually mangling the makefiles.
2020-04-19 06:41 AM
Take a look into this channel (not mine):
https://www.youtube.com/channel/UCPc2YUw_rpxWJLc4PFwSZag
There you may find everything, you need for the beginning
2020-04-19 06:41 AM
2020-04-19 06:46 AM
Ah, that's brilliant. Pick it up in some other task via uart. Thanks a bunch!
