Are there any samples code for USB Host Application?
‎2021-04-19 10:45 PM
Hi Folks,
I am trying to explore the USB Host feature for STM32 can offer, I am using STM32F769I-Discovery kit for prototyping. I was trying to find any template for reference on TouchGFX Designer default templates but could not find.
Can someone help me please?
If this request is too general, I am thinking to start by an application in which the device can detect when an USB flash drive plug in and then I can write and read data to the USB flash drive.
- Labels:
STM32F7 Series
TouchGFX
USB
‎2021-04-28 3:31 AM
Hello @BParh.1​ ,
You can check the STM32CubeF7 MCU package and you will find USB Host application which can help you as an implementation example:
STM32Cube_FW_F7_V1.16.1\Projects\STM32F769I-Discovery\Applications\USB_Host\
As reference on TouchGFX, you have the demonstration under this path:
\STM32Cube_FW_F7_V1.16.1\Projects\STM32F769I-Discovery\Demonstrations\TouchGFX
Imen
Imen
‎2021-04-28 3:31 AM
Hello @BParh.1​ ,
Imen
Imen
