AN4861 Table 10 meaning.
CScha.2
I am looking at the maximal supported pixel clock of the stm32F4x9 with SDRAM 32bit. The pixel rate for 640x320 pixels at 60hz refresh is 640*480*60 = 18432000. There is a table in AN4861 Table 10 that states the maximal supported pixel clock is 35Mhz with 1 layer 32 bpp. What exactly is this refering to ? If I take 18432000*32 = 589824000. Is the table 10 referirng to the transfer speed from the SDRAM ? Do I take this number and mulitply it by 32 or 35mhz * 32 to get the actually throughput for this device ?
3 REPLIES 3
[emphasis mine]
Why? Typo?
Note, that you'd need somewhat higher pixel clock to account for the blanking intervals, so you'd need around 20MHz (how much exactly depends on the display).
Why would you do that. One pixel is 32-bit and the whole path (except actual data to the display) is 32-bit wide.
The 35MHz value in table 10 means, that you could go up to cca 35MHz/20MHz*60Hz=105Hz frame refresh rate before the LTDC controller ceasing to be able to read out pixel data fast enough.
Or, if you look at the 2-layers value which for 32/32 bpp is 18MHz < 20MHz, i.e. you can't use two 32/32 layers at 60Hz frame rate.
CScha.2
OK. That is what I wanted to know. The max pixel rate is greater than 640*480*60, Correct ? I wanted to make sure that the did not mean I had to take the 32 bit bus in to account even though that made no sense to me. I now understand my two layer limitations as well. Thanks for the help. You can close the case.
That is, assuming some reasonable settings for the SDRAM (maybe characterized in the same AN, I don't know, I don't use LTDC) and assuming you won't use SDRAM for anything other than the video data.
