X-Cube-SbSfu
YuriCh
I have decided to try out the X-Cube-SbSfu, i have downloaded the SW from the ST website,
according to the documents available this is an expansion pack that can be added to the CubeMX.
is this correct?
where can I find information about the process that helps me accomplish this?
Imen.D
Hello @YuriCh​ ,
The SBSFU package is not configurable though CubeMX.
You can unzip the SBSFU package and import the example in STM32CubeIDE.
I advise you to review these resources related to SBSFU package, that will help you on your application:
  • UM2262 Getting started with the X-CUBE-SBSFU STM32Cube Expansion Package
  • AN5056 Integration guide for the X-CUBE-SBSFU STM32Cube Expansion Package
If you are satisfied of my answer, please mark it as "Best", so that this thread will be marked as solved.
Imen
Imen
Imen.D
Hello @YuriCh​ ,
Imen
Imen
YuriCh
thank you :)
