STSAFE
  • October 14, 2024
  • 3 replies
  • 922 views
How to authenticate a  device connected to STM 32 using USB Peripheral the STM 32 is integrated with STSAFE  IC , How to use peripheral Authentication Example for this in the software package
Hi @jijomathew ,
I'm not sure to understand your request ?
You want to authenticate a USB device connected to your STM32 device USB port ?
In your STM32 device you have an STSAFE-A and is acting as USB master ?
Best Regards,
Benjamin
Hi @Benjamin BARATTE
yes, Sir,
I want to try the peripheral authentication, in my  STM 32, I have integrated STSAFE-A, and acting as a USB master.
Thanks and Regards
Jijo Mathew
Hi @jijomathew ,
The STSAFE-A shall on the side of the peripheral you want to authenticate in that case.
Having the STSAFE-A on the USB master side will enable mutual authentication with peripheral.
The code example provided in the X-CUBE-SAFEA1 is showcasing the authentication of the STSAFE-A by the STM32. The use case is that STSAFE-A is on the peripheral side an when plugged to the I2C of the STM32, the authentication is done.
Best Regards,
Benjamin
