STM32U5 RDP regression without JTAG/SWD
‎2023-07-04 7:04 AM
Hello ST Community,
There was a thread by Aurelien about this topic, but I did not understand the answer. So let me rephrase the question with my own words.
I have a STM32U5 based device with high security settings (TZEN=1, RDP=2). Is there any other means to regress to TZEN=0, RDP=0 than OEM2KEY provisioning and JTAG/SWD communication? By software?
Regards.
Cryptography
‎2023-07-05 6:42 AM - edited ‎2023-07-05 7:48 AM
Hello @ELuca.2
It's not possible to regress RDP without JTAG. Because to define your OEM2KEY, you have to use external Debug and after activate your RDP= 2 , you will lost your degug.The only access you will be provided by Cubeprogrammer to get your OEM2KEY.
Diane
‎2023-07-06 1:57 AM
Hello Eric,
yes, it's not possible .
Diane
Hello @ELuca.2
Diane
‎2023-07-05 8:07 AM
Hello Diane,
I was thinking about directly writing the OEM2KEY into the DBGMCU_DBG_AUTH_HOST register, from a secure and privileged piece of code in the firmware, not using CubeProgrammer. You confirm it is not possible?
‎2023-07-06 1:57 AM
Hello Eric,
Diane
