Set RDP LEVEL without st link utility?
coffeeMaker
I would like to set the RDP LEVEL for my stm32l0 MCU without using ST link utility software,
to be more specific, how I can set the level in the firmware to be flashed in which area ? and is it possible to add a script to linker to set the RDP level without changing the code?
Please advice.
Thanks.
Your own code can write the options bytes any way it wants. You can have it self initiate a change based on desired vs current settings, or from your own user/command interface to your product..
thanks @Community member​
coffeeMaker
hello again,
Just following same context which is RDP, I was able to change the RDP for my MCU by Firmware, but the problem is I need to do the Power on cycle after flashing the FW so the Option bytes change, the NVIC_SystemReset() seems not working at all, my question is if my final device is battery based how I can do a POC to make sure the RDP level has been changed after first flash?
