2021-11-15 1:45 PM
I am trying to build the 3 components that comprise the "2 Images" variant of the SBSFU v2.5 package. This requires building the following components:
2_Images_SECoreBin
- 2_Images_SBSFU
- 2_Images_UserApp
The SBSFU package does not, however, come with .cproject files for STM32CUBE-IDE which is my target IDE. How can I import and compile this package and its components with the CUDE-IDE? Thanks
2021-11-16 2:06 AM
Hello
There are .cproject and .project files for System Workbench in SW4STM32 directories.
In STM32CubeIDE you can try to use "Import / Import Ac6 System workbench for STM32 projects".
Which STM32 are you using ?
2021-11-16 2:06 AM
Hello
2021-11-19 10:39 AM
@Guillaume K Thanks that did work! Though I got some conversion errors in that I am excerpting below from the conversion log file. I don't think that they are relevant. Would you be able to comment? The errors are below:
Project: NUCLEO-G071RB_2_Images_SBSFU
Converter: ST System Workbench for STM32 project converter
Date: 20211116
Unknown value type "" for id gnu.c.link.option.libs on tool fr.ac6.managedbuild.tool.gnu.cross.c.linker
Unknown value type "" for id gnu.c.link.option.paths on tool fr.ac6.managedbuild.tool.gnu.cross.c.linker
Unknown value type "" for id gnu.cpp.link.option.libs on tool fr.ac6.managedbuild.tool.gnu.cross.cpp.linker
Unknown value type "" for id gnu.cpp.link.option.paths on tool fr.ac6.managedbuild.tool.gnu.cross.cpp.linker
Option fr.ac6.managedbuild.tool.gnu.cross.cpp.linker.noexceptions is no longer supported
Option fr.ac6.managedbuild.tool.gnu.cross.cpp.linker.nortti is no longer supported
Value type err, id: gnu.cpp.link.option.flags
Unknown value type "" for id gnu.both.asm.option.include.paths on tool fr.ac6.managedbuild.tool.gnu.cross.assembler
