SBSFU: Adapting the User Application with .ld linker file
‎2021-08-25 11:03 AM
I have successfully taken the sbsfu sample code and gotten it to work on my hardware. Now, I am trying to adapt my existing application to be SBSFU compatible. Section 8.1 of AN5056 tries to explain this but the examples are all for an .icf linker file (IAR?). My linker files are .ld and completely different. Are there examples that use a .ld linker file?
Specifically, I don't know how to configure the vector table to run from active slot 1.
thanks in advance for your help,
Brent
- Labels:
X-Cube-SBSFU
‎2021-08-25 11:37 AM
Have you looked under the Linker_Common folder of the example?
e.g. ...\STM32CubeExpansion_SBSFU_V2.X.0\Projects\NUCLEO-L476RG\Applications\2_Images\Linker_Common\SW4STM32
‎2021-08-26 2:16 AM
hello,
I think this is what you are looking for
