Pre build CRC32 calculation in System Workbench
Can we insert the Pre-build CRC32 calculation in the elf file before creating the elf file under the System Workbench . Currently I am doing it using Post Build and it is not possible to Debug the Source Code if the CRC does not match .
That would seem to place the cart in front of the horse.
The trick here would be to place the CRC within the .ELF​
