Does Stm32l496zgt6 have AES hardware
ML2020
I'm working on STM32L496 for some security application, as per L4 series documents I see that L4 series controllers has AES hardware, but in my IOC settings under security option I don't see the AES.
Why is this? does it mean STM32L496 doesn't have AES hardware inbuilt? if yes is there any software approach?
3 REPLIES 3
Jocelyn RICARD
Hello @ML2020 ,
The STM32L496 does not support AES hardware accelerator.
It seems there is a mistake in the RM0351 rev 9 at beginning of chapter 28 page 833
Instead of
This section applies to STM32L49x/L4Ax devices only.
it should be
This section applies to STM32L48x/L4Ax devices only.
You can check in related datasheets.
Best regards
Jocelyn
STea
@ML2020
answering your question "if yes is there any software approach?"
if you want to do this by software you can used ST cryptographic library found in this link and a guide on how to incorporate it into you project in here .
BR
There's always a software approach..
