Can I use secp192r1 with X-CUBE-CRYPTOLIB?
crwper
Senior
I have an application where I need to use ECDSA to check a signature using the secp192r1 curve. However, I don't see a clear define for this in cmox_ecc.h. Is this supported under a different name?
Jocelyn RICARD
Hello @crwper​,
yes this curve is not provided as a predefined curve.
This means you need to provide the curve parameters with the cmox_ecc_customCurveConstruct
Best regards
Jocelyn
2 REPLIES 2
Jocelyn RICARD
Hello @crwper​,
Best regards
Jocelyn
Thank you!
