2022-02-24 05:01 AM
Hello!
I own an STM32F769I-DISCO board and I have just read that it is already possible to use a serial Wi-Fi module (called ESP8266-01). However, I have been wondering for some days whether it is also possible to use a 4G communication module with this board.
I truly thank you in advance for your help!
Lleyton
2022-02-24 05:37 AM
Sure it has a shield connector, could add one there.
Probably would need a better power-supply, or one directly to the 4G modules, and most cellular modems can pull several amps under certain conditions.
2022-02-24 05:37 AM
2022-02-27 08:33 AM
Hello!
Thank you very much for your answer!
Therefore, would you know some examples of 4G compatible modules?
Best,
Lleyton
