Why would analog watchdog fire interrupt even when the value is within the guarded range?
RDien
I am trying to catch levels out of threshold using ADC and analog watchdog on NUCLEO-L552ZE-Q. Unfortunately analog watchdog fires interrupt even when value is within the guarded range.
I came across this example: https://community.st.com/s/article/how-to-configure-and-use-the-stm32-adc-analog-watchdog-feature
and it works like a charm! But it doesn't imply catching a single event like I do.
Spend several days trying to figure out the cause and no luck. Please help!
It could be that the value which triggered it was already overwritten by the time you looked at it. You have a lot going on in there. Perhaps try a simpler example to convince yourself it's working correctly, or to show that it is not.
RDien
Yes, this thought also crossed my mind. I tried to change the threshold values blindly and seems like it works. Seems like you are right. Thanks!
