2021-08-05 6:48 AM
Hi!
I'm trying to read Sigma Delta ADC for 16-bit. It works, but it seems that everything is reverse.
For single Sigma Delta ADC I get 32767 (0x7FFF) when I apply 0 volt.
For differential Sigma Delta ADC I get 65553 (0xFFFF) when the difference is 0 volt on both inputs.
When I increase the voltage, then the ADC values....deceases. Not increases. Why?
I want at 0 Volt, the single sigma delta should show 0 ADC and at REF volt, I want the single sigma delta so show 65553 ADC.
If someone want to try out Sigma Delta ADC, here is the code.
static uint32_t Channel = 0;
static uint16_t SDADC_Single[12];
static uint16_t SDADC_Differential[5];
static float SDADC_Single_Calibration_Gain[12] = {0};
static float SDADC_Single_Calibration_Bias[12] = {0};
static float SDADC_Differential_Calibration_Gain[5] = {0};
static float SDADC_Differential_Calibration_Bias[5] = {0};
void STM32_PLC_Start_Analog_Input(TIM_HandleTypeDef* htim12, TIM_HandleTypeDef* htim13, TIM_HandleTypeDef* htim16, SDADC_HandleTypeDef* hsdadc1, SDADC_HandleTypeDef* hsdadc2, SDADC_HandleTypeDef* hsdadc3) {
HAL_TIM_OC_Start(htim13, TIM_CHANNEL_1); /* TIM13 is trigger source for SDADC1 */
HAL_TIM_OC_Start(htim12, TIM_CHANNEL_1); /* TIM12 is trigger source for SDADC2 */
HAL_TIM_OC_Start(htim16, TIM_CHANNEL_1); /* TIM16 is trigger source for SDADC3 */
if (HAL_SDADC_CalibrationStart(hsdadc1, SDADC_CALIBRATION_SEQ_1) != HAL_OK)
Error_Handler();
if (HAL_SDADC_CalibrationStart(hsdadc2, SDADC_CALIBRATION_SEQ_1) != HAL_OK)
Error_Handler();
if (HAL_SDADC_CalibrationStart(hsdadc3, SDADC_CALIBRATION_SEQ_1) != HAL_OK)
Error_Handler();
if (HAL_SDADC_PollForCalibEvent(hsdadc1, HAL_MAX_DELAY) != HAL_OK)
Error_Handler();
if (HAL_SDADC_PollForCalibEvent(hsdadc2, HAL_MAX_DELAY) != HAL_OK)
Error_Handler();
if (HAL_SDADC_PollForCalibEvent(hsdadc3, HAL_MAX_DELAY) != HAL_OK)
Error_Handler();
if (HAL_SDADC_InjectedStart_IT(hsdadc1) != HAL_OK)
Error_Handler();
if (HAL_SDADC_InjectedStart_IT(hsdadc2) != HAL_OK)
Error_Handler();
if (HAL_SDADC_InjectedStart_IT(hsdadc3) != HAL_OK) /* Differential only */
Error_Handler();
void STM32_PLC_Analog_Input_SDADC1(SDADC_HandleTypeDef* hsdadc1) {
uint16_t value = HAL_SDADC_InjectedGetValue(hsdadc1, &Channel); /* Channel will have the numbers 0,1,2,3,4,5,6,7,8 but randomly */
switch(Channel) {
case 0:
SDADC_Single[8] = value;
break;
case 1:
SDADC_Single[7] = value;
break;
case 2:
SDADC_Single[6] = value;
break;
case 3:
SDADC_Single[3] = value;
break;
case 4:
SDADC_Single[2] = value;
break;
case 5:
SDADC_Single[1] = value;
break;
case 6:
SDADC_Single[0] = value;
break;
case 7:
SDADC_Single[5] = value;
break;
case 8:
SDADC_Single[4] = value;
break;
void STM32_PLC_Analog_Input_SDADC2(SDADC_HandleTypeDef* hsdadc2) {
uint16_t value = HAL_SDADC_InjectedGetValue(hsdadc2, &Channel); /* Channel will have the numbers 0,1,2 but randomly */
switch(Channel) {
case 0:
SDADC_Single[11] = value;
break;
case 1:
SDADC_Single[10] = value;
break;
case 2:
SDADC_Single[9] = value;
break;
void STM32_PLC_Analog_Input_SDADC3(SDADC_HandleTypeDef* hsdadc3) {
uint16_t value = HAL_SDADC_InjectedGetValue(hsdadc3, &Channel); /* Channel will have the numbers 0,2,4,6,8 but randomly */
switch(Channel) {
case 0:
SDADC_Differential[4] = value;
break;
case 2:
SDADC_Differential[3] = value;
break;
case 4:
SDADC_Differential[2] = value;
break;
case 6:
SDADC_Differential[1] = value;
break;
case 8:
SDADC_Differential[0] = value;
break;
/* Get ADC0 to ADC11 */
float STM32_PLC_Analog_Input_ADC_Get(uint8_t i) {
return SDADC_Single_Calibration_Gain[i]*((float)SDADC_Single[i]) + SDADC_Single_Calibration_Bias[i];
/* Get raw ADC0 to ADC11 */
uint16_t STM32_PLC_Analog_Input_ADC_Get_Raw(uint8_t i) {
return SDADC_Single[i];
/* Set calibration ADC0 to ADC11 */
void STM32_PLC_Analog_Input_ADC_Set_Calibration(uint8_t i, float min_value, float max_value, float bias_value) {
SDADC_Single_Calibration_Gain[i] = (max_value - min_value) / (0xFFFF);
SDADC_Single_Calibration_Bias[i] = bias_value;
/* Get DADC0 to DADC4 */
float STM32_PLC_Analog_Input_DADC_Get(uint8_t i) {
return SDADC_Differential_Calibration_Gain[i]*((float)SDADC_Differential[i]) + SDADC_Differential_Calibration_Bias[i];
/* Get raw DADC0 to DADC4 */
uint16_t STM32_PLC_Analog_Input_DADC_Get_Raw(uint8_t i) {
return SDADC_Differential[i];
/* Set calibration DADC0 to DADC4 */
void STM32_PLC_Analog_Input_DADC_Set_Calibration(uint8_t i, float min_value, float max_value, float bias_value) {
SDADC_Differential_Calibration_Gain[i] = (max_value - min_value) / (0xFFFF);
SDADC_Differential_Calibration_Bias[i] = bias_value;
/* Callbacks for SDADC */
void HAL_SDADC_InjectedConvCpltCallback(SDADC_HandleTypeDef *hsdadc) {
if(hsdadc->Instance == SDADC1) {
STM32_PLC_Analog_Input_SDADC1(hsdadc);
}else if (hsdadc->Instance == SDADC2) {
STM32_PLC_Analog_Input_SDADC2(hsdadc);
}else if (hsdadc->Instance == SDADC3) {
STM32_PLC_Analog_Input_SDADC3(hsdadc);
}The sigma delta init-code looks like this.
2021-08-06 6:40 AM
Here is the solution. uint16_t should be int16_t.
16-bit ADC works as a charm! I like it. Very stable.
* Analog_Input.c
* Created on: Jun 13, 2021
* Author: Daniel Mårtensson
#include "Functions.h"
static int16_t SDADC_Single[12];
static int16_t SDADC_Differential[5];
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
switch(Channel) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
switch(Channel) {
case 0:
break;
case 1:
break;
case 2:
break;
switch(Channel) {
case 0:
break;
case 2:
break;
case 4:
break;
case 6:
break;
case 8:
break;
return SDADC_Single_Calibration_Gain[i]*((float)STM32_PLC_Analog_Input_ADC_Get_Raw(i)) + SDADC_Single_Calibration_Bias[i];
return SDADC_Single[i] + 0x8000;
return SDADC_Differential_Calibration_Gain[i]*((float)STM32_PLC_Analog_Input_DADC_Get_Raw(i)) + SDADC_Differential_Calibration_Bias[i];
2021-08-06 6:40 AM
* Analog_Input.c
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
switch(Channel) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
switch(Channel) {
case 0:
break;
case 1:
break;
case 2:
break;
switch(Channel) {
case 0:
break;
case 2:
break;
case 4:
break;
case 6:
break;
case 8:
break;
