what will be the problems of using Single VDD Pin (48PIN) connect to VDD voltage by keeping other VDD pins open ?
‎2020-06-09 04:42 AM
I'm using STM32f030C8T6 controller 48pin package ,i want to know what are the difference between digital power supply pin and complementary power supply pin . and also need to know that can i use only Digital power supply to VDD voltage for running the IC?
- Labels:
STM32F0 Series
‎2020-06-09 05:02 AM
It is the end of the world as we know it.
Using parts in a not specified way will lead to problems not specified.
‎2020-06-09 05:43 AM
The part doesn't start.
Groups of pin don't work or stop working.
Allowing other pins to float can cause unpredictable start behaviour.
Avoid lazy/sloppy design.
‎2020-06-09 06:25 AM
Not sure what you mean here. Any power supply that can source enough current can be used for VDD.
