What is the easiest way to measure phase shift between hrtim pwm and an external feedback signal?
MJavi.1
waclawek.jan
Capture the signal in the same timing unit and calculate the phase shift?
waclawek.jan
Yes.
Phase shift between output of COPM2 (ZCD) and HRTIM master.
(COPM2 used as HRTIM External Event 1 source)
Did you found a solution? I'm now facing the same problem.
