What is STPM3x's max SPI clock? I got 5MHz working but not 10MHz. Anyone get a clue? Cheers
‎2017-05-02 1:08 AM
I am using stm32f407 discovery board and STPM34 evaluation board. These boards are connected by flying wires(5cm). The max SPI clock could be influenced by the flying wire? or Do I need a impedance resistor?
#stpm3x- Mark as New
‎2017-05-02 2:00 AM
The datasheet (always a recommended read) specifies 50ns clock period, meaning 20MHz clock frequency.
Are you familiar with Laplace/Fourier transformations ?
Rectangular signals like the SPI signal can be expressed as a series of sinusoidal waves of increasing frequency.
Your cabling needs to support a bandwidth of about 100MHz for you signals, else the distortions make it increasingly unrecognizable.
Would probably help. And twisting each signal line with a ground wire, to get a consistent impedance.
You can check the signal quality on the (signal) receiver side - if you are familiar with RF measurements.
Probe impedance should match signal/cable impedance as well, else you measure rubbish ...
‎2017-05-02 2:01 AM
It seems the max SPI clock period by STMPS is 50ns ==> 20MHz?
The quality of the signal maybe important, check out the SPEED value for the STM32 GPIOs
Make sure the ground is well connected (current = ground loop path = inductance area)
Not a specialist on this slave device.
