what is _impure _ptr ? why am I getting this error ?
mehmet.karakaya
Posted on November 22, 2012 at 21:53
hello forum
I am trying to compile a C program for STM32F4 microcontroller
with Eclipse + yagarto compiler
I get the error;
undefined reference to `_impure_ptr'
there is no function ''impure_ptr'' in whole project
the error pointer points to a line containing only     }
This build of yagarto use the following versions:
binutils: 2.20.1
gcc: 4.5.1
newlib: 1.18.0
gdb: 7.1
(13.08.2010, mifi)
In my code I include
&sharpinclude <stdio.h>
&sharpinclude <string.h>
this must be something related to C compiler however I dont know what
how can I get rid of this ?
#eclipse-yagarto
5 REPLIES 5
Andrew Neil
Evangelist III
Posted on November 22, 2012 at 22:34
''undefined reference to `_impure_ptr'''
Where, exactly, do you get that?
Show the code.
''there is no function 'impure_ptr' in whole project''
Why do you think it's a function?
mehmet.karakaya
Posted on November 23, 2012 at 13:12
hello , here is a screenshot
I searched google - it says this error is related to newlib or something like that
however I couldnot find any answer how to solve this problem
frankmeyer9
Posted on November 23, 2012 at 13:38
Have you tried that ?
http://communities.mentor.com/community/cs/archives/arm-gnu/msg03556.html
mehmet.karakaya
Posted on November 23, 2012 at 15:39
hello , I think you suggest me to change something here in makefile
what do I need to change in below makefile ?
# Makefile for compiling the Getting Started project
# User-modifiable options
# Trace level used for compilation
# (can be overriden by adding TRACE_LEVEL=#number to the command-line)
# TRACE_LEVEL_DEBUG 5
# TRACE_LEVEL_INFO 4
# TRACE_LEVEL_WARNING 3
# TRACE_LEVEL_ERROR 2
# TRACE_LEVEL_FATAL 1
# TRACE_LEVEL_NO_TRACE 0
TRACE_LEVEL
= 4
# Optimization level
OPTIMIZATION
= -O0
# Output file basename
OUTPUT
= main
# Output directories
BIN
OBJ
= obj
# library dirs
LIBRARYSRC
= ./lib/src
STARTUPFILE
= ./lib/startup_stm32f4xx.s
# Tools
# Tool suffix when cross-compiling
CROSS_COMPILE
= arm-none-eabi-
CC
$(CROSS_COMPILE)
gcc
SIZE
$(CROSS_COMPILE)
size
STRIP
$(CROSS_COMPILE)
strip
OBJCOPY
$(CROSS_COMPILE)
objcopy
OBJDUMP
$(CROSS_COMPILE)
objdump
LD
$(CROSS_COMPILE)
ld
AS
$(CROSS_COMPILE)
as
# Files
# include folders
INCLUDES
= -I./
INCLUDES +
= -I./lib/
INCLUDES +
= -I./lib/inc/
INCLUDES +
= -I./lib/inc/../../
# Objects built from C source files
C_OBJECTS
$(OBJ)
/main.o
C_OBJECTS +
$(OBJ)
/system_stm32f4xx.o
C_OBJECTS +
$(OBJ)
/stm32f4xx_gpio.o
C_OBJECTS +
$(OBJ)
/stm32f4xx_rcc.o
C_OBJECTS +
$(OBJ)
/stm32f4xx_it.o
C_OBJECTS +
$(OBJ)
/stm32f4xx_syscfg.o
C_OBJECTS +
$(OBJ)
/stm32_eth.o
C_OBJECTS +
$(OBJ)
/ethernet.o
C_OBJECTS +
$(OBJ)
/clock-arch.o
C_OBJECTS +
$(OBJ)
/timer.o
C_OBJECTS +
$(OBJ)
/misc.o
C_OBJECTS +
$(OBJ)
/uip.o
C_OBJECTS +
$(OBJ)
/httpd.o
C_OBJECTS +
$(OBJ)
/uip_arp.o
# Objects built from Assembly source files
ASM_OBJECTS
$(OBJ)
/startup_stm32f4xx.o
LINKER_SCRIPT
= ./lib/stm32f4xx_flash.ld
#LINKER_SCRIPT = ./lib/stm32f4xx_flash_extsram.ld
# Append OBJ and BIN directories to output filename
OUTPUT :
$(BIN)
$(OUTPUT)
# Rules
# Flags
CFLAGS
= -Wall -fno-common -c -g -
mcpu
=cortex-m3 -mthumb
CFLAGS +
= -g
$(OPTIMIZATION)
$(INCLUDES)
DTRACE_LEVEL
$(TRACE_LEVEL)
ASFLAGS
= -g -mapcs-32
LDFLAGS
= -g -v -nostartfiles
OBJCOPYFLAGS
= -O binary
OBJDUMPFLAGS
= -x --syms -S
all:
$(BIN)
$(OBJ)
$(OUTPUT)
.out
$(BIN)
$(OBJ)
mkdir $@
$(OUTPUT)
.out:
$(C_OBJECTS)
$(ASM_OBJECTS)
$(LINKER_SCRIPT)
@ echo ''..linking''
$(LD)
$(LDFLAGS)
-Map
$(OUTPUT)
.map -T
$(LINKER_SCRIPT)
-o
$(OUTPUT)
.out
$(C_OBJECTS)
$(ASM_OBJECTS)
libgcc.a
$(OBJCOPY)
$(OBJCOPYFLAGS)
$(OUTPUT)
.out
$(OUTPUT)
.bin
# $(OBJDUMP) $(OBJDUMPFLAGS) $(OUTPUT).out > $(OUTPUT).lss
@ echo ''...completed.''
$(C_OBJECTS)
: main.c system_stm32f4xx.c
@ echo ''.compiling''
$(CC)
$(CFLAGS)
-o
$(OBJ)
/main.o main.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/system_stm32f4xx.o system_stm32f4xx.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/stm32f4xx_it.o stm32f4xx_it.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/stm32_eth.o stm32_eth.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/ethernet.o ethernet.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/clock-arch.o clock-arch.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/timer.o timer.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/uip.o uip.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/httpd.o httpd.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/uip_arp.o uip_arp.c
@ echo ''.compiling libraries''
$(CC)
$(CFLAGS)
-o
$(OBJ)
/stm32f4xx_gpio.o
$(LIBRARYSRC)
/stm32f4xx_gpio.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/stm32f4xx_rcc.o
$(LIBRARYSRC)
/stm32f4xx_rcc.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/stm32f4xx_rcc.o
$(LIBRARYSRC)
/stm32f4xx_rcc.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/stm32f4xx_syscfg.o
$(LIBRARYSRC)
/stm32f4xx_syscfg.c
$(CC)
$(CFLAGS)
-o
$(OBJ)
/misc.o
$(LIBRARYSRC)
/misc.c
$(ASM_OBJECTS)
$(STARTUPFILE)
@ echo ''.assembling''
$(AS)
$(ASFLAGS)
-o
$(OBJ)
$(STARTUPFILE)
clean:
-rm -f
$(OBJ)
/*.o
$(BIN)
/*.out
$(BIN)
/*.bin
$(BIN)
/*.dmp
$(BIN)
/*.map
$(BIN)
/*.lss
Posted on November 23, 2012 at 16:12
The linker is driven by the LD and LDFLAGS lines, fix those.
