JTrau.1
We have multiple STM32 uC on board and would like to share as many connections for programming the parts.
  • September 2, 2020
  • 12 replies
  • 3035 views
Is there a way to connect them in parallel with some individual enable to reduce the outward interface of the board. ie maybe connect everything in parallel except for RST line or ??? any suggestions would be appreciated
    Ozone
    Principal
    September 2, 2020
    JTAG can be daisy-chained.
    I would suggest to consult the JTAG standard, I never used that feature myself.
    Or start e.g. here: http://www.pemicro.com/blog/index.cfm?post_id=136
    JTrau.1
    JTrau.1Author
    I see some info on web that suggests STlink cant handle this connection for programming parts, but perhaps other debugger/programmers can?
    Tesla DeLorean
    Guru
    September 2, 2020
    Really a software issue.
    You'd need more industrial software rather than low-rent consumer stuff.
    Segger used to have libraries for industrial/automation users, and specialized JTAG experience is out there in the test/measurement world, but expect to have to pay for it.
    waclawek.jan
    Which STM32?
    Can't the factory bootloader be used in some way?
    Tesla DeLorean
    Guru
    September 2, 2020
    Yes, I expect one could mux the UART connection, or selectively hold devices in reset so that one could be programmed at a time.
    Could mux TX outputs with diode tree and pull-up
    JTrau.1
    JTrau.1Author
    Ya, this is what i was thinking and why I shy'd away from it
