2020-11-18 11:51 PM
2020-11-19 12:41 AM
There is a nice app note "AN5093 Application note Getting started with STM32G4 Series hardware development boards" with a ref design.
You can use the same voltage for VREF+, you can/should filter it (see ref design) for better results or you may use some external (more precise, independent,different) ref. voltage if you prefer.
