VDDA and PA2 ADC measurements
Jérémy Da Silva
Posted on August 30, 2017 at 15:48
I work on a STM32L151CCU6 and I need your help.
I try to measure VDDA voltage in order to calculate a voltage divider on PA2 (single mode). My two ADC configuration functions are :
void MX_ADC_Init(void)
  GPIO_InitTypeDef gpioInit1;
  GPIO_InitTypeDef gpioInit2;
    gpioInit1.Pin = PID_PIN; //PA2
    gpioInit1.Mode = GPIO_MODE_ANALOG;
    gpioInit1.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(PID_PORT, &gpioInit1); PA2
    gpioInit2.Pin = PID_POWER_SUPPLY_PIN; //PB2
    gpioInit2.Mode = GPIO_MODE_OUTPUT_PP;
    gpioInit2.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(PID_POWER_SUPPLY_PORT, &gpioInit2); //PB2
  __HAL_RCC_ADC1_CLK_ENABLE();
  ADC_ChannelConfTypeDef sConfig;
    /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  adc_identification.Instance = ADC1;
  adc_identification.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV2;
  adc_identification.Init.Resolution = ADC_RESOLUTION_12B;
  adc_identification.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  adc_identification.Init.ScanConvMode = ADC_SCAN_DISABLE;
  adc_identification.Init.EOCSelection = ADC_EOC_SEQ_CONV;
  adc_identification.Init.LowPowerAutoWait = ADC_AUTOWAIT_DISABLE;
  adc_identification.Init.LowPowerAutoPowerOff = ADC_AUTOPOWEROFF_DISABLE;
  adc_identification.Init.ChannelsBank = ADC_CHANNELS_BANK_A;
  adc_identification.Init.ContinuousConvMode = DISABLE;
  adc_identification.Init.NbrOfConversion = 1;
  adc_identification.Init.DiscontinuousConvMode = DISABLE;
  adc_identification.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  adc_identification.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  adc_identification.Init.DMAContinuousRequests = DISABLE;
  if (HAL_ADC_Init(&adc_identification) != HAL_OK)
    while(1);
    /**Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
  sConfig.Channel = ADC_CHANNEL_2;
  sConfig.Rank = 1;
  sConfig.SamplingTime = ADC_SAMPLETIME_384CYCLES;
  if (HAL_ADC_ConfigChannel(&adc_identification, &sConfig) != HAL_OK)
    while(1);
  ADC_Enable(&adc_identification);
and :
void MX_ADC_VDD_Init(void)
  /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)*/
  VDD_measurement.Instance = ADC1;
  VDD_measurement.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  VDD_measurement.Init.Resolution = ADC_RESOLUTION_12B;
  VDD_measurement.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  VDD_measurement.Init.ScanConvMode = ADC_SCAN_DISABLE;
  VDD_measurement.Init.EOCSelection = ADC_EOC_SEQ_CONV;
  VDD_measurement.Init.LowPowerAutoWait = ADC_AUTOWAIT_DISABLE;
  VDD_measurement.Init.LowPowerAutoPowerOff = ADC_AUTOPOWEROFF_DISABLE;
  VDD_measurement.Init.ChannelsBank = ADC_CHANNELS_BANK_A;
  VDD_measurement.Init.ContinuousConvMode = DISABLE;
  VDD_measurement.Init.NbrOfConversion = 1;
  VDD_measurement.Init.DiscontinuousConvMode = DISABLE;
  VDD_measurement.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  VDD_measurement.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  VDD_measurement.Init.DMAContinuousRequests = DISABLE;
  if (HAL_ADC_Init(&VDD_measurement) != HAL_OK)
    while(1);
  sConfig.Channel = ADC_CHANNEL_17;
  sConfig.Rank = 1;
  sConfig.SamplingTime = ADC_SAMPLETIME_4CYCLES;
  if (HAL_ADC_ConfigChannel(&VDD_measurement, &sConfig) != HAL_OK)
    while(1);
  ADC_Enable(&VDD_measurement);
When I try to measure this two ADC channel, I find 0.
I use this function : HAL_ADC_GetValue(&VDD_measurement);
Does anyone know where is my problem?
Thanks,
Jérémy
4 REPLIES 4
Posted on August 30, 2017 at 20:45
Hello!
This function gets converted value only.
Also your ADC_SAMPLETIME_4CYCLES is small.  My suggestion is to increase it at least to ADC_SAMPLETIME_96CYCLES  and after you have a success reading try to calculate the exact timing.
Try to use
uint32_t vdda;
#define VREFINT_CAL_ADDR ((uint16_t*) (0x1FF800F8U)) /* Internal voltage reference,
#define VREFINT_CAL_VREF                   ( 3000U)                    /* Analog voltage reference
HAL_ADC_Start(&VDD_measurement);
vdda=VREFINT_CAL_VREF*(*VREFINT_CAL_ADDR);//VDDA = 3 V x VREFINT_CAL / VREFINT_DATA
HAL_ADC_PollForConversion(&VDD_measurement, 1000);
vdda /=HAL_ADC_GetValue(&VDD_measurement);
The vdda value will be in millivolts.
Use the same way to read the PA2  Start, Wait, Read.
vf
Posted on August 31, 2017 at 10:42
Hello!
Thank you ! That is working well for VDDA but not for PA2.
I have changed the Init function like below:
  adc_identification.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  adc_identification.Init.LowPowerAutoWait = ADC_AUTOWAIT_UNTIL_DATA_READ;
    while(1);
  sConfig.Rank = 1;
  sConfig.SamplingTime = ADC_SAMPLETIME_96CYCLES;
    while(1);
And I read the value of the voltage like :
void ADC_Measure(ADC_HandleTypeDef* hadc)
        MX_ADC_Init(); //Init ADC
        ADC_PowerOnPin(); //Enable the 3.3V of the voltage divider
        ADC_Start(hadc);
        HAL_ADC_PollForConversion(hadc, 1000);
        ADC_Measure_ID =HAL_ADC_GetValue(hadc);
        ADC_PowerOffPin(); //Disable the 3.3V of the voltage divider
        ADC_Stop(hadc);
But I receive 0. I use exactly the same parameters in initialization as for VDD and the same measurement function too.
Any idea for this point?
Thank you for your help.
Jérémy Da Silva
Posted on September 04, 2017 at 10:22
Any ideas?
Thank you.
Posted on September 04, 2017 at 17:11
Hi
in GPIO initialization function the GPIO clock seems not enabled.
__HAL_RCC_GPIOX_CLK_ENABLE();
