2026-01-14 12:01 AM
Is this normal? if yes, I may move the LSE initialization later.
2026-01-14 3:07 AM
Hi @xufl
I have found your issue is already under investigation internally 224687 and you can reach your local FAE for further updates.
2026-01-14 3:07 AM
Hi @xufl
2026-01-25 8:11 PM
Hi FBL,
Is there any progress on your investigation? Have you reproduce this issue? FAE does not get any update. And I need to report the latest status to cutstomer and management.
Best Regards.
XuFL
2026-01-27 6:18 AM
Hello Jason,
Just phoned you, and will update you asap. sorry for inconvenience.
Best regads
Gavin LIU.
