2017-11-04 11:46 AM
I'm using STM32F407 Discovery-1, I use USB CDC to send and receive data from terminal. Everything ok but issue that I need re-connect port to transmit and receive data, but i remember that when i used
STM32F407 Discovery , every when i upload new code, i don't need to re-connect port. I use CubeMx 4.14 for both STM32F407 Discovery versions. Please help me to resolve this problem. Sorry for bad my english.
2017-11-06 3:25 AM
Hello
thaitanloi365
,Please use the last version of CubeMx 4.23 and firmware package STM32CubeF4.
Have a look to the CDC application from CubeF4 package and you canstart with a working USB example to identify what is going wrong in your case and confirm if the problem here seems related to the hardware or software environment.
Best Regards
Imen
2017-11-06 5:27 AM
Thanks for your recommendation, I have used other versions as CubeMx 4.19,4.22 and 4.22.1 and other firmware versions as V2.J28.M18 Debug +Mass storage and latest firmware version, but the problem isn't resolved. I had to re-connect port every i upload new code. I confirm that when i use this code for STM32F407
Discovery
( not Discovery 1 ' with firmware ST-LINK V2 Debug. This problem is fiexed.
