Uart : what is the difference between IDLE and RTO interrupts
‎2024-05-23 3:09 AM
Can I say that "IDLE" is equivalent to "RTO with 8-10 bits (depending on framing)"?
Or are there some other subtle differences?
My goal is to transfer received data with DMA and start interpretation of the data when nothing is received on the line which, in my application's world, is equivalent to an end of frame.
Julien
- Labels:
STM32G0 Series
UART-USART
‎2024-05-23 5:15 AM
There is a good explanation here
‎2024-05-23 5:15 AM
‎2024-05-24 1:35 PM
Short answer: RTO is what you want to use. IDLE is what you don't want, if RTO is available.
‎2024-05-27 1:56 AM - edited ‎2024-05-27 1:57 AM
Thanks for your answer, it's exactly what my experiments lead me to understand.
Delay is the only difference between RTO and IDLE.
‎2024-05-27 3:21 PM - edited ‎2024-05-27 3:28 PM
No, delay is not the only difference between RTO and IDLE.
The IDLE condition occurs when the UART receives the "idle frame". So when the RX line is silent and IDLEIE set, the UART will continuously generate IDLE interrupts. RTO timeout starts counting after at least one data byte is received (after its stop bit TL;DR); it won't occur just when RX line is silent. Easier to manage. This is the behavior you actually want (and the reason why this feature exists at all).
The IDLE detection serves also another purpose, to wait for opportunity to transmit when multiple devices share the comm line or wait until noise disappears.
