2019-01-29 07:41 AM
How can i change the Frequency/Speed by which the Data is transfered to the UART TX pin?
2019-01-29 08:41 AM
Change the BRR (Baud Rate Register) to reflect the division from the APB you which to achieve. Expect you might have to disable USART while you do this, and you should make sure all pending data has been sent. Incoming bytes might be lost. And you might have to clear noise or framing errors.
2019-01-29 11:44 PM
UartHandle.Init.BaudRate = 9600;
How can I set up te BRR Register for my USART3?
