TSC Example
mihaheh
I am a begginer in the st enviroment, but still. I'm trying to use the touch sensing library, but there is very little good examples of how to just use one button as a sensor. I real all the documentation, still no good examples. I downloaded the libraryen.stm32cubel0_v1-12-0\STM32Cube_FW_L0_V1.12.0\Middlewares\ST\STM32_TouchSensing_Library, but the documentation is still refering about using tsl_user.c, which there isn't one in the folder... Can someone link an example or something that helps. Im using nucleo-l053r8
Stassen.C
Hello Mihaheh,
In the STM32CubeL0 you downloaded, you can look into the STM32CubeL0 Projects 32L0538DISCOVERY Applications TouchSensing
AScha.3
You can look on git also:
https://github.com/STMicroelectronics/STM32CubeL0/blob/master/Projects/32L0538DISCOVERY/Applications/TouchSensing/TouchSensing_Linear/Src/tsl_user.c
FBL
Hello @mihaheh and welcome to ST Community
Getting started with touch sensing control on STM32 microcontrollers - Application note should be helpful to get started. You can find example project as mentioned @AScha.3
If you still having concerns, don't hesitate to come back and share them.
Best regards,
FBL
Stassen.C
Hello Mihaheh,
