Timer rising edge
Options
‎2013-07-30 11:33 PM
Posted on July 31, 2013 at 08:33
I'm working with stm32f2. I need example code, to count time between two rising edge of GPIO. I read somewhere, that is possibile by appropriate timer's configuration without GPIO's interrupt. Can you help me?Thanks #pwm-input
Labels:
TIM
Options
‎2013-07-31 5:37 AM
Posted on July 31, 2013 at 14:37
You'd use a TIM with CHx in ''input capture'' mode, have it interrupt on CCx and compute the delta of values latched in CCRx between one event and the next.
Options
‎2013-07-31 8:57 AM
Posted on July 31, 2013 at 17:57
Or, try PWM Input mode, this way you get a 0-based delta.
Examples are in the FW library. Edison
