Timer 1 Output for Power switches in a Power Supply using a STM32G031 controller
danielbathtub
Has anyone fed the Analog Watchdog Internal Signal output into Timer 1 on the STM32G031K6 ? To Drive Mosfet power switches of a Power Supply, The Analog Watchdog is used to limit the current. The timer 1 also has a break function and some fancy features designed to drive power switches. Any help/suggestions would be appreciated.
Thanks.
Sarra.S
Hello @danielbathtub
The ADC can provide a trigger event through analog watchdog signal ADC_AWDx_OUT to TIM1_ETR
