2020-10-05 02:35 AM
2020-10-05 05:08 AM
Ok, and what have you learned in the debugger, having stepped in from Reset_Handler ?
Check your design for BOOT0 pin/settings.
Check your HSE clock source is present and starts properly.
2020-10-05 02:43 AM
I run it in debugging.
2020-10-05 05:08 AM
2020-10-05 06:22 PM
Thank you. I solved it。BOOT0 pin must be set Low。I opened it。😂
it
