the adc result in dual mode are not in the right order
H.Darwish
hello
i am using stm32f103 for reading a 10 adc channels and i am using Dual mode regular simultaneous with DMA , the result are loaded in a buffer.
the problem is the loaded data from the ADC1 are in the right order (1st data is from 1st channel)
but the data from ADC2 are in the right sequence , for example : the last register in the buffer array is corresponding to the rank 3 of ADC2
how i can fix this
10 REPLIES 10
My recollection with the F1+SPL is that I configured DMA in 32-bit wide mode and read the ADC CDR (Common Data Register)
I'm afraid I can't analyze CubeMX/HAL code in an unpaid capacity.
