2023-12-26 09:51 PM - last edited on 2024-02-20 07:56 AM by Peter BENSCH
Hi Folks,
Managed to get the source compiled and loaded for the inverted pendulum project. Rather impressive.
In the source code there's sprintf statements to inform the user on what's going on.
My question is: How can I view these messages?
I'm a bit rusty with STF401 code, just forgotten how to do things.
Can someone please help me?
Thanks,
John.
2024-01-04 02:01 AM - edited 2024-01-04 02:07 AM
No - just try it :
in IDE , bottom window : console view
click on -> small dropdown arrow , right -> command shell console
you get :
first time : -> New ....then choose the USB-serial (on your system maybe COM9 or...)
and you are there.... 🙂
(next time : name field should show your already made connections )
IDE (eclipse) is very powerful - just the problem is: how to find or set , what you want (not only for you, same for me...).
Then looks like this - when connected:
2024-01-04 09:52 AM
Thanks ASsch.3.
The STM32CubeIDE is a most complex piece of software. The terminal is NOT part of the original download, you need to download is a separate step.
I can now start a terminal session but alas I haven't worked out what the Baud Rate is. All I get displayed are random characters but at least that's something.
I will keep trying.
2024-01-04 09:58 AM - edited 2024-01-04 10:10 AM
--- most times : 115200 --- but just look in the source (UART2 setting, in MX_UART2_init), you said, you have it. I dont.
in my ide 1.13.1 , it was there ... afair. But not sure about this. 🙂
2024-01-04 07:46 PM
Hi AScha.3,
Good news, I checked the huart2 structure and found the baud rate was set 230,400, not quite a standard rate and very fast.
I found a declaration of SAMPLE_BAUD_RATE = 230400.
I changed it 9,600 baud and all works well.
Thanks for your assistance in solving this problem.
