stpm34 INT1 LED1
Yang Shufan
Posted on December 16, 2016 at 10:46
  • I could see how to set LED1 as Primary current SD bit stream. But I could not find how to set INT1  as primary SD voltage bit stream?
  • What is the bit stream speed(is it original 7.8125kHz?, I mean to get VxData[0-23] and CxData[0-23] of all samples)?
2 REPLIES 2
Imen.D
Posted on December 16, 2016 at 11:51
Dear
Yang.Shufan
Welcome to our community,
You can find information and more clarification inthe STPM34
http://www.st.com/content/ccc/resource/technical/document/datasheet/d9/c1/c6/3d/09/7f/4f/7b/DM001118pdf/files/DM001118pdf/jcr:content/translations/en.DM001118pdf
Hope thishelps you.
Best Regards
-Imen-
Imen
Posted on December 16, 2016 at 12:31
I read it many times. I am asking because I cannot find it in datasheet.
