2011-05-02 05:50 AM
stm32w_flasher with STM32W-RFCKIT
2011-05-17 05:33 AM
Hi kilian,
ST did not test stm32w_flasher.exe on Win7 64 bit machine. Actually the error you get about FTDI should be harmless. In fact the board you are using are equipped with STM32F as USB to RS232 converted. In order to troubleshoot your problem, you should: 1) Check that the appropriate driver is loaded fromhttp://www.st.com/internet/com/SOFTWARE_RESOURCES/SW_COMPONENT/SW_DRIVER/vcpdriver_v1.zip
2) The COM port number is not in conflict with another COM port allocated for other purposes (This should not normally happen but we have been reported such problem 3) I guess you are adminstrator of your PC and the registry entries are readable. Best Regards Michele2011-05-17 05:33 AM
Could anyone tell me where to buy this STM32W-RFCKIT? I live in Ireland and having trouble flashing STM32W108 with ST-Link. May be the stm32w_flashed might help. Thanks.
