STM32VL-discovery pinout versus protoboard
Options
‎2010-11-05 12:07 PM
Posted on November 05, 2010 at 20:07
Hi, Why the pinout of the board is so protoboard unfriendly?
I had to tear apart my protoboard to make it work ok... take a look athttp://maujabur.blogspot.com/2010/11/stm32-discovery-pinout-fail.html
3 REPLIES 3
Options
‎2010-11-05 3:39 PM
Posted on November 05, 2010 at 23:39
Yes - it is pretty daft, isn't it?!
If you look carefully at the left of this photo, you can see that I adopted exactly the solution as you: Here's a close-up:
Options
‎2010-11-11 10:16 PM
Posted on November 12, 2010 at 07:16
Not what I would call ''protoboard friendly'' for sure... But it wouldn't really be a big deal to lop the P3 pins off since they are not going to be mating anyway.
Just a thought :)Options
‎2010-11-11 11:08 PM
Posted on November 12, 2010 at 08:08
Still a pain if you actually wanted to use those pins...
Yes, the easiest ''fix'' for ST (without re-spinning the board) would be to simply not fit those pins.
