STM32N657-DK board bug or NC?
matt-crc
Senior III
In the default configuration, the SMPS on the development board is disabled.  As such the VDDA18PMU appears to be floating.  According to the spec sheet, it says that the pin MUST be tied to Vss when the SMPS in not used.  Is there an internal pull down?
0 REPLIES 0
