2022-01-25 05:42 AM
How do I implement a watchdog timer for the L4P5ZG device? I have the LPTIM1 example running but I do not see a built-in watchdog timer for this device under the timer tab.
2022-01-25 05:53 AM
Welcome, @Community member, to the community!
you'll find the watchdogs IWDG and WWDG:
Good luck!
/Peter
2022-01-25 05:53 AM
Good luck!
/Peter
2022-01-25 06:23 AM
Peter, thank you.
Sincerely Timothy [personal data removed by moderator]
2022-01-25 06:54 AM
If the problem is resolved, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
/Peter
