STM32L476 issue
‎2016-02-09 2:18 PM
I'm trying to load demo SAI_audio-play from firmware package ''STM32Cube_FW_L4_V1.3.0'' into the flash but I can't, one error send me ==> Error: Flash Download failed - Target DLL has been cancelled.My setting in ''option for target'' are:device tab: STM32L476VG debug tab:- Mark as New
‎2016-02-09 3:02 PM
Try ''Connect : Under Reset'' option, or strapping BOOT0 High. You can't debug a device that powers down.
Will definitely need to have the algorithm selected in the menu.Up vote any posts that you find helpful, it shows what's working..
‎2016-02-11 2:21 AM
Thank you, thanks to your piece of advice, I can load the program into the flash memory.
My settings according your specification:- Mark as New
‎2016-02-11 2:46 PM
I can load te program into flash memory (SAI_AudioPlay) of my µcontroler but there is no sound from my headphone...
So I checked in debug mode and the problem is located in that part of the code: Main.c/* Check if the buffer has been loaded in flash */
if(*((uint64_t *)AUDIO_FILE_ADDRESS) != 0x017EFE2446464952 ) Error_Handler();
I toggle towards Error_Handlers() function in while(1) loop.
I am trying to solve my problem but currently I didn't find where is located the problem.
Need some help plz!
‎2016-02-13 2:36 PM
Someone can tell me what is the program loaded by default in the STM32L476-disco ?
Example ==> BSP ?thanks- Mark as New
‎2016-02-13 3:14 PM
Ok I did it, just I forgot to load the audio.bin into the flash memory with ST-link utility.
‎2016-02-18 8:04 AM
Hi julien.terrier,
To answer your question: ''Someone can tell me what is the program loaded by default in the STM32L476-disco ?'':It is the project that you find under STM32Cube_FW_L4_V1.3.0\Projects\STM32L476G-Discovery\Demonstrations.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
‎2016-02-20 3:59 AM
Thank you for your answer.
But someone could exlain me what's meaning of this line of code (from your own project SAI_AudioPlay):/* Check if the buffer has been loaded in flash */
Especially ==> 0x017EFE2446464952
It's flash size ? Or at least one part ?
‎2016-02-20 7:55 AM
A ''RIFF'' format audio file with length?
RIFF File Formathttps://en.wikipedia.org/wiki/Resource_Interchange_File_Format
https://msdn.microsoft.com/en-us/library/windows/desktop/ee415713%28v=vs.85%29.aspx
‎2016-02-21 9:08 AM
0x017EFE2446464952
Is RIFF file and if I translate in ASCII code I obtain ==>0x017EFE2446464952
RIFF$þ(SOH)~
Better with ST-link utility I can understand your link and chunks storage.
