STM32L052 USART: Problem Switchover from Output- to UART - TX - functionality produces a disturbing H/L - edge on TX
‎2021-08-13 9:04 AM
Two Usart - TX - lines shall be used either in PP- output- or in Usart - TX - mode.
The switchover from a normal output pin to a Uart - TX - pin produces
an High/ Low edge on TX followed by an interrupt on TX side.
On RX- side this H/L edge causes an unwanted Interrupt too. And that is the actual problem.
The cause is the following sequence
u32ModeBack = GPIOA->MODER;
u32ModeBack &= ~(GPIO_MODER_MODE2_Msk | GPIO_MODER_MODE15_Msk);
u32ModeBack |= (0x02ul<<GPIO_MODER_MODE2_Pos); //Alternate output function
GPIOA->MODER = u32ModeBack;
Is there a possibility to avoid this additional output of pulses?
STM32L0 Series
UART-USART
‎2021-08-17 7:10 AM
Update:
Now I have achieved a clean switch from output to Uart-Tx by changing the order of IO initialization:
//RX + TX Pull Up
u32ModeBack = GPIOA->PUPDR;
u32ModeBack &= ~(GPIO_PUPDR_PUPD2_Msk | GPIO_PUPDR_PUPD15_Msk);
u32ModeBack |= (GPIO_PUPDR_PUPD2_0 | GPIO_PUPDR_PUPD15_0);
GPIOA->PUPDR = u32ModeBack;
//Alternate function = Usart 2
GPIOA->AFR[0] &= ~(GPIO_AFRL_AFSEL2_Msk);
GPIOA->AFR[0] |= (GPIO_AF4_USART2<<GPIO_AFRL_AFSEL2_Pos);
GPIOA->AFR[1] &= ~(GPIO_AFRH_AFSEL15_Msk);
GPIOA->AFR[1] |= (GPIO_AF4_USART2<<GPIO_AFRH_AFSEL15_Pos);
//Switch to alternate function
u32ModeBack |= (GPIO_MODER_MODE2_1 | GPIO_MODER_MODE15_1);
Many thanks for your help
‎2021-08-13 9:33 AM
So it goes from a high GPIO pin, then low immediately when initialized as AF, then high again without changing anything?
Is the USART peripheral initialized prior to switching it to AF? External pullup present?
‎2021-08-13 1:33 PM
What interrupt?
Post a minimal but complete compilable example exhibiting the problem.
‎2021-08-16 7:27 AM
Hi TDK and Jan,
Meantime I know, that from my point of view I made the error to use the flag
USART_ISR_TXE instead of USART_ISR_TC for controlling of usart - tx - interrupt - routine.
The flag USART_ISR_TXE created my initial problem:
An interrupt without writing anything.
OK, now I useUSART_ISR_TC. That wastes time but is fast enough for max.19200 Baud.
The correct solution would be a combined using of USART_ISR_TC and USART_ISR_TXE I guess.
For the elimination of problem two I have taken into account the question of TDK regarding of pull-ups.
Before switching to alternate function the internal TX - pull up is switched on and some instruction
later switched off again. Perhaps this cast can be removed when I am more familiar with STM32- USARTs.
Many thank for your help
‎2021-08-17 7:10 AM
Update:
//RX + TX Pull Up
