STM32L0 EEPROM programming with keil
‎2017-07-03 10:57 PM
Hello, everybody.
Hello everybody. I use Keil and ST-Link for programming STM322L073 Flash and EEPROM. I try to program them simultaneously but only Flash is written.
Is there any way of writing Flash and Internal EEPROM simultaneously?
BR, Anastasiia
‎2017-07-04 6:13 AM
Hi
Anastasia.Ivanova
,You can have a look to the
FLASH
example available under/external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fcontent%2Fst_com%2Fen%2Fproducts%2Fembedded-software%2Fmcus-embedded-software%2Fstm32-embedded-software%2Fstm32cube-embedded-software%2Fstm32cubel0.html
, get inspired from the example and modify it
to achieve your goal
STM32Cube_FW_L0_V1.9.0\Projects\STM32L073Z_EVAL\Examples\FLASH
Also, y
ou can found a full set of
EEPROM
examples within STM32CubeL4,which can help you as an implementation example to build your application on L0.I recommend you to have a look to the “Flash program memory and data EEPROM (FLASH)�? section in your related STM32L0 product reference manual
/external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Fresource%2Ftechnical%2Fdocument%2Freference_manual%2F21%2Fbd%2F0f%2Fbd%2F1c%2F88%2F40%2Ff0%2FDM00108pdf%2Ffiles%2FDM00108pdf%2Fjcr%3Acontent%2Ftranslations%2Fen.DM00108pdf
.Hope this helps you.
Imen
Imen
‎2017-07-05 4:36 AM
hi,
In my STM32L053 device, I also got 2K eeprom @0808 0000 - 0808 07FF.
If I create a const array with absolute address, such as:
const uint8_t eepromArray[16] __attribute__((at(0x08080000)))
= {0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F};
If I use Keil to flash, it will skip this area, for there is no programming algorithm at this section.
(for the moment, i don't know how to add or modify programming algorithm for keil).
But if I use the output hex file and ST-Link to program,
the eeprom is indeed programed.
Even though the ST-Link Utility only shows the the read out data in flash region, but it's indeed programmed.
In ST-Link, you may manually modify the memory display range like this
you can also confirmed this by using software code or by STMFlashLoader Demo.
I prefer use software codes to erase/write/read the eeprom data,
it seems that the above way for initializing the eeprom area does no harm too.
Zt.
‎2017-07-05 6:43 AM
Hello, dear Zhital Liu!
Thank's a lot for your advise. I also hope it helps me!
Best regards, Anastasiia
‎2017-07-06 4:32 AM
Also too programming the EEPROM from Keil IDE, in the options for targer->Debug->Settings->Flash Download
Add and select the EEPROM option.
‎2017-07-06 7:09 AM
Great! That's what I missed! Thx,
Cordoba_Papamija.Jho
!- Mark as New
‎2017-07-06 11:49 PM
Hello, dear Jhon!
Thak's a lot. I think it will work for me!!!
