STM32L-Discovery USB-UART Communication
ndonj86
Posted on October 04, 2014 at 18:34
Hi people,
I'm new in STM's world!
Thanks to this forum, I made the USB - UART connection on STM32L-Discovery.
Now, I have to test speed communication with a byte array of max 20 bytes.
I use STM32_USB-FS-Device_Lib, example virtual_COM_port for stm32l-eval. Can someone help me with code to inizialize and send an array via uart-usb and vice-versa?
Sorry for my bad english!
Thank you all!
5 REPLIES 5
ndonj86
Posted on October 09, 2014 at 23:12
Hi Guys,
can sameone help me???
Do you need more explanations about my project??
Thanks for help....
Posted on October 09, 2014 at 23:33
The pool is pretty shallow here, if the project has a budget consider some of the contractors.
ST maintains a list of consultants and contractors.
http://www.st.com/web/en/support/mcu_design_consultants.html
ndonj86
Posted on October 10, 2014 at 20:11
Thanks Clive...
Unfortunately
I have no
budget.
I'm just a
beginning student
with this card
for educational purposes
I thought
someone had
already
had experience with
this type of connection
, though not
with
this
exact
card
I
just
need some guidance
maybe
from someone who has
used
these libraries
where to insert
a function
in a loop
sending each
byte
on the other side
(via USB
to
UART
or
UART
to
USB)
Andrew Neil
Posted on October 11, 2014 at 20:05
''I'm just a
beginning student
I
just
need some guidance''
And that is what your teachers & tutors are there for!
If you're stuck with your course work, those are really the people you should be going to for help.
ndonj86
Posted on October 14, 2014 at 21:41
So OK.
thank you all
anyway!
