STM32H7 direct channel
‎2021-12-14 5:44 AM
i am using stm32h723zg nucleo board, I'm using adc's direct channe, h723zg have only PC2_C,PC3_C,.
Firs ı use this function and no noise>LL_SYSCFG_CloseAnalogSwitch(LL_SYSCFG_ANALOG_SWITCH_PC2|LL_SYSCFG_ANALOG_SWITCH_PC3);
second ı use this function and ıts have noise->
LL_SYSCFG_OpenAnalogSwitch(LL_SYSCFG_ANALOG_SWITCH_PC2|LL_SYSCFG_ANALOG_SWITCH_PC3);
What is the reason for the noise in the second function?,
I can only resolve the noise in the second one by increasing the resolution ratio.
no noise at low resolution in the first
- Labels:
ADC
STM32H7 Series
‎2021-12-14 6:02 AM
Noise is not a binary thing. How much noise do you see in each case? What signal are you monitoring? Adding capacitance on the line, which is a side of effect of closing the switch, will act to stabilize the value.
‎2021-12-14 6:13 AM
I'm reading pc2_c and pc3_c with the timer, when I use the first function it returns 4095 at 3.3v on both channels.,
when I use the second function. At 3.3v pc2_c returns 4095 and pc3_c returns 4086. This only happens when I use the second function
‎2021-12-14 6:14 AM
resulation 12 bit
‎2021-12-14 6:28 AM
Okay, so zero counts of noise? Same exact value every time you call the ADC? How are PC2 and PC3 configured? How is the ADC configured? Lots of missing data here.
Read:
‎2021-12-14 6:36 AM
no missing information,,
yes it gives more or less the same values, You don't need an extra definition for direct channels, they are already defined as analogue. What I don't understand here is that the noise changes with the switch state. it seems to me that there should be no noise in the second function
‎2021-12-14 6:43 AM
‎2021-12-14 6:49 AM
You're commenting without even understanding what I'm asking. good luck
