STM32F767 flash programming problem
gsaru.1
Hi everyone,
We are trying to program the MCU flash memory to write and save some data on it.
After successfully writing to a single sector, we can't delete the sector content anymore.
We are using HAL_FLASHEx_Erase to delete the sector.
In particular, we use the ideas in this article https://controllerstech.com/flash-programming-in-stm32/
Thanks in advance.
5 REPLIES 5
Are you asking a Question, or making a statement?
Well the HAL FLASH functions do work properly on the F767's, so perhaps review the Reference Manual, or looks at the examples provided in CubeF7 for the board..
gsaru.1
Asking a question...
Correction to the original post - after a single write(that might have failed) to a sector, when we try to write/overwrite the same sector we fail. Already read the Reference Manual (and I'm sure the HAL FLASH functions work properly), hence looking for advice on how to proceed from here/ things to think about that we might have missed.
Javier1
Principal
Recomended reading RM0410
I have never used an F7, what about the single/dual bank bits?
hit me up in https://www.linkedin.com/in/javiermu%C3%B1oz/
every time you want to write FLASH, the entire flash page needs to be erased.
https://community.st.com/s/question/0D53W00001hkN4aSAE/hardfault-when-i-try-to-program-in-the-flash-memory
What i usually end up doing is:
  1. copy entire flash page to ram buffer
  2. modify the part of the ram buffer i want
  3. erase flash page
  4. copy back RAM buffer into erased flash page
jbake_uni
For dual bank information you can use this resource:
STM32F7 Series Flash memory dual bank mode, software expansion for STM32Cube (AN4826)
