2015-10-01 5:06 AM
When I use the function to play sound (BSP_AUDIO_OUT_Play or BSP_AUDIO_OUT_Changebuffer) I heard a noise like a commutation. This noise is not really a big problem on big size buffer but when I read small buffer this noise is reapeated often. So my question is : does a solution exist to avoid this noise ? Thanks for any support2015-10-07 3:37 AM
Hi haye.dorian,
Could you please precise the range of ''big size buffer'' and small ones?Is the issue faced with Cube example or your own code?This helps to check deeply the reported issue.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
