STM32F401RE Timer setup
stforum
Posted on December 24, 2015 at 18:32
I'm getting started with the 'F401 device, I'm trying to blink the LED on the Nucleo-F401RE board when Timer2 triggers. I know this is just register level stuff and I'm probably making things harder for myself doing this, but I'd like to get a feel for what's actually happening.
This is what I have so far - I know I'm missing something, but I can't see what. Any thoughts?
.ExternalClass1321C468BAEA455C841E37159325A9B4 p, .ExternalClass1321C468BAEA455C841E37159325A9B4 li {white-space:pre-wrap;}
The
LED
pin
shares
with
TIM2_CH1
TIM2_ETR
alternate
functions
AF01
according
to
the
data
sheet
&sharpinclude
''stm32f4xx.h''
int
main
void
RCC
AHB1RSTR
RCC_AHB1RSTR_GPIOARST
Reset
GPIOA
RCC
AHB1RSTR
0
Exit
reset
state
RCC
AHB1ENR
RCC_AHB1ENR_GPIOAEN
Enable
GPIOA
clock
RCC
APB1ENR
RCC_APB1ENR_TIM2EN
Enable
Timer
Clock
GPIOA
MODER
GPIO_MODER_MODER5_1
Set
GPIOA.5
to
Alternate
function
(Took
some
digging
to
find
this!)
GPIOA
AFR
0
0x100000
Set
Alternate
function
AF01
on
pin
5
(defines
seem
to
be
missing?)
TIM2
PSC
29999
I
think
the
counter
clock
is
84Mhz,
divide
it
down
a
bit.
Prescale
PSC
+1
TIM2
ARR
1
Auto
start
at
1
on
roll
over
TIM2
CCR1
500
Value
to
compare
with,
500
seems
a
nice
number...
TIM2
CCMR1
TIM_CCMR1_OC1M_0
TIM_CCMR1_OC1M_1
Output
changes
on
channel
1
compare
match.
Also
took
some
finding!
TIM2
CCER
TIM_CCER_CC1E
Enable
compare
for
return
0
#nucleo #stm32f #timers
6 REPLIES 6
Posted on January 02, 2016 at 15:36
Basic blinkey (LED at GPIO output, loop delay) works?
TIM2
ARR
1
Auto
start
at
1
on
roll
over
TIM2
CCR1
500
Value
to
compare
with,
500
seems
a
nice
number...
By default, timers are upcounters and are reset at reaching the TIMx_ARR value, thus TIM2 never reaches 500.
for
return
0
What?
stforum
Posted on January 03, 2016 at 11:01
Thank you!
I'd totally misunderstood the timer roll over.
It's working now.
TIM2
ARR
501
a test value
TIM2
CCR1
500
Value
to
compare
with,
500
seems
a
nice
number...
// do nothing and keep the compiler happy.
for
return
0
Posted on January 03, 2016 at 11:57
for
return
0
This is equivalent to return 0 alone, which is not ''do nothing''.
The startup code might have saved the day, if it's written with a true infinite loop after call to main().
chernobay
Posted on December 28, 2015 at 22:45
TIM2->CR1 |= TIM_CR1_CEN    //start timer
stforum
Posted on December 31, 2015 at 11:04
Thanks - but that doesn't seem to fix things (though not enabling the timer was a big mistake).
stforum
Posted on January 04, 2016 at 21:25
Sorry, that's an error with me copying and pasting from my terminal - it should have been
for(;;)
Best wishes,
David
